Determining the maximum number of minority electrons in semiconductor
Discussion in 'Homework Help' started by tahayassen, Sep 16, 2013.
  1. tahayassen
    Apr 1, 2013
    1. The problem statement, all variables and given/known data
    P-type silicon can be doped in the range from 5x10[SUP]14[/SUP] cm[SUP]-3[/SUP] to 10[SUP]20[/SUP] cm[SUP]-3[/SUP]. Determine the maximum possible number of minority electrons in a neutral P-type region if the device area is limited to A[SUB]D[/SUB] = 1 cm x 1 cm and the thickness of the P-type region is limited to t[SUB]P[/SUB]=100 μm. Assume room temperature and full acceptor ionization. n[SUB]i[/SUB] = 1.02 x 10[SUP]10[/SUP] cm[SUP]-3[/SUP]
    2. Relevant equations
    3. The attempt at a solution
    Solution:
    Maximum\quad concentration\quad of\quad minority\quad carriers\quad is\quad obtained\quad for\quad the\quad minimum\quad doping\quad level:\\ n=\frac { { { n }_{ i } }^{ 2 } }{ { N }_{ A } } =\frac { { (1.02*{ 10 }^{ 10 }) }^{ 2 } }{ 5*{ 10 }^{ 14 } } =2.1*{ 10 }^{ 11 }\quad { m }^{ -3 }\\ The\quad maximum\quad volume\quad is:\\ V={ A }_{ D }{ t }_{ p }={ (0.01) }^{ 2 }(100)({ 1 }0^{ -6 })={ 10 }^{ -8 }\quad { m }^{ 3 }\\ N=nV\\ =2.1*{ 10 }^{ 3 }
    My confusion is how they got this equation:
  2. anhnha
    Apr 19, 2012
    776
    48
