Determining specs of LED display without a datasheet
Discussion in 'The Projects Forum' started by djsfantasi, Feb 14, 2016.
  1. djsfantasi
    Thread Starter AAC Fanatic!
    Apr 11, 2010
    2,916
    881
    I purchased an UXCel 1" 7 segment display on Amazon. They're from China apparently. 5 parts for the price of 1 similar part on Digikey. Never have made a purchase like this before. However, there was no datasheet. Is there anyway of making measurement that will allow me to calculate Vf and I?
  2. bertus
    Administrator
    Apr 5, 2008
    15,807
    2,390
  3. djsfantasi
    Apr 11, 2010
    2,916
    881
    Yes, exactly. Are you psychic?
  4. ScottWang
    Aug 23, 2012
    4,936
    777
    You can using 2V/20mA to test it, if the brightness is enough then just use that value, otherwise you can increasing the current a little more to test.
    And this kind of 7-segs led, when you do the testing, you need to using some plastic(or glass) color paper to cover it.
  5. djsfantasi
    Apr 11, 2010
    2,916
    881
    Thanks for the process. One question: the 1" displays on Digikey (LDS-CA14RI) that look similar (horizontal versus vertical pin layout) look like their Vf is 4V. Am I reading the datasheet wrong?
  6. ScottWang
    Aug 23, 2012
    4,936
    777
    The Vf is 4V, because they used two Leds to be one segment, but the dp(dot point) still used one led, so it still 2V, you can using 20mA to try it.
    djsfantasi likes this.
  7. djsfantasi
    Apr 11, 2010
    2,916
    881
    D'oh! I knew that, but forgot. Thanks for your explanation.
  8. bertus
    Administrator
    Apr 5, 2008
    15,807
    2,390
  9. ScottWang
    Aug 23, 2012
    4,936
    777
    Bertus showing that just using one led for one segment.
  10. bertus
    Administrator
    Apr 5, 2008
    15,807
    2,390
    To determine if there is one or two leds in a segment use a 5 volts powersupply and a resistor of say 220 Ohms and measure the voltage accross the segment.
    This would be safe for 1 led in a segment as the current will be (5-2)/220 ≈ 14 mA.
    For 2 leds in a segment the current will be about 4.5 mA, wich will still give a visible segment.
    Bertus
