Determining input capacitor
Discussion in 'General Electronics Chat' started by pradeeba, Feb 28, 2008.
  1. pradeeba
    Thread Starter Active Member
    Feb 27, 2008
    104
    What is the Formula for calculating input Capacitor in a SMPS?
  2. rherber1
    Member
    Jan 6, 2008
    15
    A very open-ended and not too specific question...
    You need to provide a lot more detail. For example;
    Input requirement - is it DC input or off-line?
    Output requirement - what output power?
  3. pradeeba
    Feb 27, 2008
    104
    for eg: my input is 20-60 VAC,50 Hz, & my output power is 17W.
  4. nomurphy
    Aug 8, 2005
    567
    12
  5. pradeeba
    Feb 27, 2008
    104
    I think all are aware of the thumb rule for determinig input caapcitor.
    I/P Voltage Cin
    115V 2uF/W
    230V 1uF/W
    85-270V 2....3uF/W
    But my input voltage range is 20-60 VAC.
    Then how to determine input capacitor. am looking for a formula so that i can calulate the value.
  6. rherber1
    Member
    Jan 6, 2008
    15
    There is nothing critical at all to worry about so there is no need for a specific or accurate calculation. Ball park on the high side is good enough.
    You can see from the figures you quote that for a low end input voltage of 85V, a value of 3uF/W is nominal. Therefore, the lower input voltage you use the larger the capacitance/W needs to be. for 20 - 60V guesstimate 5uF/W which gives you around 85uF for 17W. Now you won't be able to buy a cap with this value so you go to a readily available value larger than this, eg. 100uF.
    Of course the major factor governing your final decision will be "how much space is available for your caps"? Will a 100uF cap fit in? If you have more than enough space you may be better off going for a 150uF cap because in this case "bigger is better" in regard to filtering and input regulation.
