determining date of the week
Discussion in 'Homework Help' started by mCatalin, May 1, 2014.
  1. mCatalin
    May 1, 2014
    5
    I have a project to make for my Digital Systems Design laboratory, which is a
    programmable office agenda. I need to display, each at a time, Date(day,month and year), clock(hour and minute), temperature, and THE DAY OF THE WEEK, and i need help for the last one, how can i find the day of the week from the date? (I need to make this project in Active Hdl) I don't need the entire solution but just an idea to make me start. Thank you.
  2. shteii01
    Feb 19, 2010
    3,500
    511
    By day of the week do you mean a number?
    Like: Monday would be 1, first day of the week. Tuesday would be 2, second day of the week. Like that?
    Also. Are we doing English week where Sunday is first day of the week?
    mCatalin likes this.
  3. mCatalin
    May 1, 2014
    5
    I need to display with text and Monday is first day of the week.. but it doesn't matter once i found the number of the day i know how to decode it from binary to display as i want...
    Also: for date i used zecimal counters, 4162 i think.. and every number of date correspond to 1 counter so: 2 counters for day, 2 for month and 4 for year.
  4. MrChips
    Oct 2, 2009
    12,633
    3,453
    I have a programming blog which may help you with Days of the Week.
    Edit: Sorry, I reviewed my code and it doesn't do what you are asking. I have this in another project that I will have to dig up.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    Consider the following:
    If you know that a certain reference date, say January 1, 2014, fell on a Wednesday and you know that the date is question, say May 1, 2014, is 120 days after the reference date, can you figure out what day of the week May 1, 2014 is?
    Once you figure out how to get the DOW given the information above, the next problem is to figure out how to find how many days have elapsed between two dates.
  6. n1ist
    Mar 8, 2009
    171
    16
    Look up "Zeller's Congruence"
    /mike
  7. mCatalin
    May 1, 2014
    5
    yes.. but i have no idea how to implement that formula with sequential logic circuits...
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  9. mCatalin
    May 1, 2014
    5
    yes but i don't know how to implement those algorithms with circuits (i need a hint about what should i use, counters, MUXs, or whatever...)
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    The proper way would probably be to use a microcontroller. This is a computational problem that is best dealt in software.
    Short of that, you could start with a very brute force approach. Can you make a counter circuit that keeps track of the date (year, month, day)? If so, then all you need to do is initial that circuit to a known reference date and then set a simply modulo-7 counter to the value corresponding to day of the week for that reference date. Then simply advance both counters until you get to the target date. Done.
    If you want to do a more elegant approach based on one of the many algorithms that are out there, then first make sure that YOU understand the algorithm and can walk through it successfully. Then implement the circuits that perform each piece of it. Your comprehension of the algorithm will tell you what components you need. We can help guide you, but it needs to be in response to YOU showing that you understand the algorithm and the discussion needs to be on issues associated with specific aspects of implementing that algorithm.
  11. mCatalin
    May 1, 2014
    5
    Thank you WBahn for your response... I chose to make it with a modulo-7 counter and I found a solution for the moment when i set the current date..
    If is a bisect year i need to increment the counter 2 times and if it is not just once, if the month has 31 days and i increment it than i need to increment the counter 3 times, 2 times for 30 days, 1 time for bisect year February. How can i give 2 or 3 clocks on the counter from 1 signal?
