determining balanced 3 phase loads
Discussion in 'General Electronics Chat' started by matt11111, May 14, 2009.
  1. matt11111
    May 12, 2009
    11
    how can I determine if a machine is a balanced 3 phase load? Is it indicated on a nameplate on the machine?
  2. Pich
    Mar 11, 2008
    119
    Name plate will indicate maximum running load and is usually engineered to be balanced. The machine may not be balanced depending on the electrical equipment intalled (like single phase heaters). the only way to be sure is to mesure the current on each phase.
  3. mik3
    Feb 4, 2008
    4,846
    63
    What loads are you referring too?
    Usually 3 phase loads are balanced as to cause an even current distribution in all the 3 phases.
