Determine which wire is which on this transformer
Discussion in 'Power Electronics' started by fred62, Jul 20, 2016.
  1. fred62
    Mar 23, 2016
    5
    Please take a look at this transformer. It was on a power supply board with the following information.
    115V 60Hz 0.4A
    Out
    +5V 2.0 A
    +12V 0.7A
    -12V 0.3A
    Which two output wires (A to F) should I use, if I want to get 12V AC with at least 2A out of this transformer ? (I don't need DC voltage)
  2. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    First measure which windings are connected or common resistance test, next simply power the primary and measure the AC outputs that had continuity between them.
    Max.
  3. hp1729
    Nov 23, 2015
    2,105
    235
    I don't see a possibility of getting 12 V at 2 Amps out of that.
  4. SLK001
    Nov 29, 2011
    852
    243
    I can't get +12V at 2 amps out of this transformer, since it is rated at +12V @0.7A. The wattage of the xformer right now is 22 watts - you want 24 watts. You will need a bigger transformer.
  5. fred62
    Mar 23, 2016
    5
    Thanx Max,
    I measured
    A-B 29.4V
    A-C 14 V
    E-F 12.6 V
    Is there a way to be sure which is going to give me 2 Amps ?
  6. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Going by the apparent wire gauge, the size of the bridge rect and the large caps, I would say you should be plenty OK with 2a.
    The transformer looks capable of 50va.
    Max.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    Use it and see if the magic smoke escapes..........................................
    One of the wire pairs looks to be bifilar wound - that winding is the highest current.
