Determine voltage gain for the CE amplifier.
Discussion in 'Homework Help' started by BruceBly, Aug 6, 2012.
  1. BruceBly
    Jul 26, 2012
    25
    I need to find out what the voltage gain is for this CE amplifier.
    I have calculated the DC voltages and currents for this circuit but I am at a loss when it come to finding the voltage gain. Can someone tell me where to start. Below is what I have for the DC part of the circuit.
    VR2=15V[4.7k/(22k+4.7k)]=2.64045V
    VRE=2.64045V-.7V=1.94045V
    IE=1.94045V/390=4.97551mA
    IC=4.97551mA
    VRC=4.97551mA(1.0k)=4.97551V
    VCE=15V-(1.94045V+4.97551V)=8.08404V
    VC=1.94045V+8.08404V=10.02449V
    VB=2.64045V
    VE=1.94045V
  2. absf
    Dec 29, 2010
    1,493
    374
    You didnt include the values of C1 to C3. What type of signal at what frequency and amplitutde are you using for input?
    What is the transistor you used and at what gain?
    Did you try simulating the circuit using LTSpice?
  3. #12
    Nov 30, 2010
    16,661
    7,305
    Crudely put, the gain is almost Rc/Re (assuming the capacitors are large enough to not interfere)...but not quite. There is a loss due to Vbe changing a little with the change in collector current.
    Gotcha pointed in the right direction?
    BruceBly likes this.
  4. BruceBly
    Jul 26, 2012
    25
    I believe I was over thinking this problem. This is what I have came up with for the answer. Can someone confirm this for me?
    r'e=25mV/4.97551mA=5.02461Ω
    Av=1.0kΩ/5.02461Ω=199.02042
  5. Yakima
    Member
    Jan 23, 2012
    35
    Good work! You are correct!
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The circuit has no negative feedback so it is extremely distorted if its output level is more than moderate.
    With an input of 30mV peak then its positive-going output is squashed to +3.5V peak and its negative-going output is -5.9V peak. It is impossible to measure its voltage gain.
    If the input signal is only 2.3mV peak then its distortion is much lower and its voltage gain is 170.
    A load will reduce its voltage gain.
    absf likes this.
  7. BruceBly
    Jul 26, 2012
    25
    This circuit was right out of my text book for me to analyze. I suppose I should have stated that in the first post. I'm not expected to build this circuit.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    I did not build the circuit, instead I simulated it. Soon you might be taught how to simulate circuits using simulation software like I did. If I did build it my results would be the same.
    All the circuits I design and build use negative feedback to accurately set the gain lower, then the distortion is very low at any amplitude.
    spark8217 and BruceBly like this.
