When will you get the hint that you are expected to show YOUR best attempt to solve YOUR homework problems instead of just asking others to work them for you (or to tell you how to work them)?
How do I determine the polarity of capacitors?
So would you have gotten the same results if you had started on the right side?I started with the left \( 8V\) battery and took the left side of C1 to be + and than the right side - and so on
Do we assume all capacitors are the same type and value? Would it make a difference?
My attempt:
Not so much same type (e.g., mylar vs. ceramic), though the leakage will impact the final distribution and we can only assume negligible leakage.Do we assume all capacitors are the same type and value? Would it make a difference?
