determine resistor for LED
Discussion in 'The Projects Forum' started by risky fajar, Oct 20, 2014.
  1. risky fajar
    Oct 8, 2014
    41
    hill all... i will questions.. how to determine resistor can be used LED with working voltage of LED 2 volt and LED series structured as much 500 LED..thanks
    risky
  2. flat5
    Nov 13, 2008
    403
    17
    Trying to understand you.
    You have 500 LEDs that you want to put in one series string.
    You expect each LED to drop the voltage across it by 2 volts.
    Why one long string of 500?
    Why not 20 strings of 25?
    The voltage required will be much safer to work with.
    (Less risky)
    We need more information about the LEDs.
    What current does each LED need?
  3. risky fajar
    Oct 8, 2014
    41
    LEDs current is 1 mA... and LED string series.... and only one source voltage...whether 500 leds string series and how drop voltage on each conettions LEDs...??? thanks
  4. flat5
    Nov 13, 2008
    403
    17
  5. risky fajar
    Oct 8, 2014
    41
    oke thanks for your answer
  6. Dodgydave
    Jun 22, 2012
    5,150
    769
    2V per led and 500 in series, thats 1000V , OUCH!
