Determine resistance value
Discussion in 'The Projects Forum' started by FND, Sep 7, 2009.
  1. FND
    Apr 2, 2009
    16
    Hi All,
    How do I determine the value of R to be used when I'm using a 9v battery to power an LED with voltage rating of 3v?
    Help please.
  2. loosewire
    Apr 25, 2008
    1,584
    435
    Go to aac books,check ohms law.
  3. FND
    Apr 2, 2009
    16
    Sorry, this thing some what makes me really confused.
    I don't know the current, so how would i know the resistance? The only info I have is the LED's Voltage rating is 3V.
    How? I know it's the most basic thing and it's a silly question. But please help understand.
    Thank you.
  4. loosewire
    Apr 25, 2008
    1,584
    435
    Where there a current meter,there a way.
  5. FND
    Apr 2, 2009
    16
    ok. Thank you. silly me
  6. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Resistance value for current limiting for an LED = (Vcc-Vf)/I
    Vcc = supply voltage = 9v
    Vf = LED forward voltage (anywhere between 1.8 -4.3V for different types)
    I = Led current (Normally 15 or 20mA) , use as 0.02 in formula.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Bad advice, loosewire! :(
    I hope our OP did not follow it, as they probably fried their LED or meter by now.
    jj_alukkas gave the proper reply. I usually spell it out a little bit more.
    The basic formula is:
    Rlimit >= (Vsupply - Vf_LED) / DesiredCurrent
    Vsupply needs to be higher than Vf_LED, of course.
    In your case, assuming your LED's Vf was measured at 20mA current:
    Rlimit >= (9v - 3v) / 20mA
    Rlimit >= 6v/0.02A
    Rlimit >= 300 Ohms
    300 Ohms is a standard value of resistance. You can use a higher value of resistance, but you should not go lower, or you risk burning out your LED.
    There is a table of standard resistance values on this site:
    http://www.logwell.com/tech/components/resistor_values.html
  9. loosewire
    Apr 25, 2008
    1,584
    435
    Thanks,Sgt. Will be more careful.
  10. FND
    Apr 2, 2009
    16
    Thank again to all of you for helping out.
    Appreciate it very much, really helped!!
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    You cannot buy a 3.0V LED. They have a range of voltage like 2.5V to 3.5V.
    If you do not measure its actual voltage then your circuit must limit the current enough that a low voltage LED does not burn out and must allow enough current for a high voltage LED to be bright enough.
