Determine length of side of right triangle for given angle?
Discussion in 'Math' started by spinnaker, Oct 29, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,163
    I have a solar panel mounted on a fence post. I need to adjust the panel angle throughout the year.
    Instead of requiring a protractor, I would like to make a graduated scale marked with the months. To make the job easier, I would like to measure one of the sides of the triangle to set the required angle.
    Example below. How would I calculate the length of side B for 26°?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    I believe, in this application A will be changing.
    You want to use the fixed length C.
    sin(angle) = B/C
    where the angle is in radians, i.e.
    angle in radians = (angle in degrees) x 3.14159 / 180
    spinnaker likes this.
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    The correct equation is
    B = A * tan(angle)
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Are you familiar with the law of sines? It is one of those formula I hang on to, because it tends to fill in for so many problems.
    A / Sine Angle A = B / Sine Angle B = C / Sine Angle C
    The Angles are opposite the sides. I'll stick in an illustration when I have more time.
  5. blah2222
    May 3, 2010
    565
    33
    This is correct, something seems to be in my water. Sorry about that.
  6. spinnaker
    Oct 29, 2009
    5,065
    1,163
    I take back my thanks. :)
  7. imasoundhound
    Oct 28, 2012
    you can't.
    you have to have the measure of at least one side of the triangle in order to use any of the trigonometric functions.
    assuming side C is the solar panel, and therefore of constant length, any change made to the angle formed by sides A and C will change the lengths of sides A and B (remember C doesn't change). If the measure of the angle increases, B must get longer while A gets shorter. If the measure of the angle decreases, B will get shorter while A gets longer.
    if C is of constant length, then:
    C*sin (26 degrees) = B
    and
    C*cos (26 degrees) = A
