determine current needed to drive a speaker
Discussion in 'Homework Help' started by nearownkira, Apr 1, 2008.
  1. nearownkira
    Feb 19, 2008
    20
    the speaker I bought said something like 800 ohm 5W, 8 ohm 25W or 8 ohm 25W.is there a formula or something to calculate.
  2. mik3
    Feb 4, 2008
    4,846
    63
    do you have the reference number of the speaker?
  3. silvrstring
    Mar 27, 2008
    159
    It sounds like your max current rating would be about 1.76 A if you have a typical 8 ohm speaker. P=(I^2)R. In the same way, P=(V^2)/R. So the voltage would be around 14V. That's what your alternator normally puts out.
    Are you using an amp?
  4. nearownkira
    Feb 19, 2008
    20
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Those are very small 8 ohm speakers. The 50mm one has a max power rating of only 0.25W.
    The max power might be its peak power so then its max RMS power from a sine-wave is only 177mW.
    Then the RMS current at max power is 149mA RMS.
  6. nearownkira
    Feb 19, 2008
    20
    how do you calculate all those number?
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
