Detector circuit compatible with SICK sensor GL6-P4111
Discussion in 'The Projects Forum' started by formach, Feb 19, 2013.
  1. formach
    Sep 4, 2012
    hi All,
    im working on a project to create a small circuit so i can detect any movement that passing the path. Every time someone walk through it there will be a green light (output 1 on sensor) while red light indicates normal condition(output 0). im using SICK sensor GL6-P4111.
    so is there any references that i can use to make the circuit?
    thank you so much for your time :)
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Post the manual of the sensor (in english please).
