Detecting very low level low freq?
Discussion in 'The Projects Forum' started by DC_Kid, Jan 15, 2016.
  1. DC_Kid
    Thread Starter Distinguished Member
    Feb 25, 2008
    640
    9
    so, in dead of night when outside has low ambient noise, from inside i can hear a low level (faint) hum, in the range of 250Hz. any ideas to build a simple directional detector that 1) can detect the frequency, and 2) allow me to get an idea as to the direction the sound is emanating from. i suspect the sound is coming from a nearby pool pump, but would be neat to build a detector that can help solve the mystery (and stop annoying me).
    since i am working another project that may use piezo element, how about mounting a bare piezo element to a 1/2" thick vertical AL plate or wood with heavy base, couple that to a high gain opamp? just not sure if 250Hz would couple well to a piezo element, might get ran over by noise in the gain. i guess one side of piezo should be on heavy mass while the other side couple to a "fork" that has resonance down low near 250Hz?
    your thoughts?
  2. GopherT
    Nov 23, 2012
    6,303
    4,019
    Use two microphones back-to-back (one on each side of a 3/4" piece of plywood (to block/deaden sound). Then connect to differential amplifier. You will need to zero the signals with a pot on one of the microphones to zero the delta in a silent room. Then rotate and find the biggest response to the + input on your op amp or instrumentation amp.
    Have fun.
  3. Kermit2
    Feb 5, 2010
    3,845
    963
    Get a stethoscope and you will find your noise
  4. Lestraveled
    May 19, 2014
    1,957
    1,217
    Remember the old conical megaphones? Make one out of cardboard, press it against your ear and go hunting.
  5. DC_Kid
    Feb 25, 2008
    640
    9
    the diameter around 1.5ft ?
  6. Lestraveled
    May 19, 2014
    1,957
    1,217
    Sounds Good
  7. #12
    Nov 30, 2010
    16,665
    7,310
    Styrofoam works, too.
    ps, 250 Hz isn't consider, "Low" in some frames of reference, like power line frequency or musical instruments. 250 Hz is near the fifth string on a guitar.
  8. GopherT
    Nov 23, 2012
    6,303
    4,019
    I have a piece of plywood in the garage - if I would have had Styrofoam, I would have suggested that.
    #12 likes this.
  9. #12
    Nov 30, 2010
    16,665
    7,310
    I have a piece of styrofoam in the laundry room...left over packing from a garbage disposer. That's why I thought of it. Besides that, styrofoam heads are used for testing headphones, so styrofoam probably works in the audio range.
    GopherT likes this.
