I struggle to understand this, but to no avail so far........
Power dissipation issues:
You need to look at power dissipation when the transistor is saturated. In many datasheets, typical saturation curves are shown where Ib=Ic/10. Basically, you want to stick with that formula; whatever you expect to see as the collector current, provide 1/10 of that for the base current. If you fail to provide enough base current, the transistor will drop out of saturation, and power dissipation in the transistor will increase dramatically.
Is it not the main function of the transistor (at least in this circuit) to amplify the current? So that I(base) x hFE = I(collector)?
With my very limited understanding I would say it is important to keep the transistor out of saturation, so that the amplification occurs as expected.
What am I missing?
What would it mean if I say: "The power dissipation of the transistor is too high"? Would that be the same as if I said:
"The maximum power rating for the transistor is beeing exceeded"?
