Hi
I have an electric jeep for my daughter, which I recently added a "boost" button to bump the voltage a little
The jeep now consists of a 12v and a 6v battery. I have a charger which has a switch on it to change from 6v to 12v for charging each battery.
http://www.thebatteryshop.co.uk/durite-612-volt-27-amp-lead-acid-battery-charger-485-p.asp
What I'd like to do is have a single charging port on the vehicle (like a lighter socket/plug) to plug the charger into and have a circuit to detect if its currently set to 12v or 6v and switch the charging to the appropriate battery.
Attached is a circuit diagram of the wiring in the jeep in its current form.
Any thoughts on how best to do this?
Thanks for your help.
Nick.
Nick.
