detecting 3 push of a button
Discussion in 'Embedded Systems and Microcontrollers' started by bug13, Aug 10, 2016.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    What is the best not blocking way to detect a 3 pushes of a button. I am thinking this:
    Code (Text):
    1.
    2. uint16_t timeArray[3];
    3.
    4. btnThreePush()
    5. {
    6.   if (btnRead()) timeArray[i++] = ticksNow;
    7. }
    8.
    9. // main loop
    10. while(1)
    11. {
    12.   diff = getDifferent(timeArray);
    13.   if (diff > some_time)
    14.   {
    15.      // do something with 3 push
    16.   }
    17. }
    18.
    Any flaws? or any better way to do it? Thanks guys
  2. nsaspook
    Aug 27, 2009
    3,011
    2,356
    It depends on whether it's three pushes ever or three pushes over a timed period (maybe starting with the first push).
  3. SLK001
    Nov 29, 2011
    849
    242
    How are you debouncing the button pushes?
  4. bug13
    Feb 13, 2012
    1,213
    38
    Say over 1 second
  5. bug13
    Feb 13, 2012
    1,213
    38
    Here is how I usually do it, these codes are usually in my timer interrupt, struct inputs is global variable
    Code (Text):
    1.                 if (!SET6_PORTbit)    // if low
    2.                 {
    3.                     if (db < INPUT_BTN_DEBOUNCE)
    4.                         db++;
    5.                     else
    6.                         inputs.set6 = 1;
    7.                 }
    8.                 else
    9.                 {
    10.                     if (db != 0)
    11.                         db--;
    12.                     else
    13.                         inputs.set6 = 0;
    14.                 }
  6. nsaspook
    Aug 27, 2009
    3,011
    2,356
    I might put the three button decision logic in btnThreePush() instead of the while loop (diff = ...) if possible as it wastes cpu cycles computing an event (3 presses timed or not) that can be detected and flagged with a variable or status check function for the while loop when the button is pressed in btnThreePush().
    bug13 likes this.
  7. xainnasir
    Nov 8, 2012
    26
    you need to use button debounce code. Code is as follows for single click check so you have to repeat it for three times:
    Code (Text):
    1. int reading = digitalRead(buttonPin);
    2.   if (reading != lastButtonState) {
    3.     lastDebounceTime = millis();
    4.   }
    5.
    6.   if ((millis() - lastDebounceTime) > debounceDelay) {
    7.     if (reading != buttonState) {
    8.       buttonState = reading;
    9.
    10.       if (buttonState == HIGH) {
    11.         ledState = !ledState;
    12.       }
    13.     }
    14.   }
  8. bug13
    Feb 13, 2012
    1,213
    38
    Sorry for the confusion, my btnRead() is already deal with debounce.
  9. djsfantasi
    Apr 11, 2010
    2,900
    876
  10. bug13
    Feb 13, 2012
    1,213
    38
    that's the same principle in my code in post #5, but pic doesn't usually have as many IO interrupt AVR, so I did my scan in a timer interrupt.
  11. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The favourite hardware way is a SPDT pushbutton and a pair of 2 input inverting gates wired as a bistable.
  12. ErnieM
    Apr 24, 2011
    7,436
    1,625
    OK, but how does it denounce? My debounce code is tucked away in a timer interrupt that fires every 25 ms and can detect stale button presses.
    To get three pulses out of this I would look at a scheme such as this: on the first valid push I would set a count variable to 1 and also start a timing variable. On subsequent checks of the button for denounce I would check the timing variable; should it exceed 1 second I reset the count variable, and if it also detects another button push then increment the count variable. You may want to also reset the timing variable too so your main code has enough time (another second?) to detect a count of three.
    This way the same way you read buttons you can also check for a count of the pressings.
  13. dannyf
    Sep 13, 2015
    2,196
    417
    that's the right approach (to put debouncing in the lower level routines).
    I would use a state machine to detect key presses. For example, you receive consecutive NO_KEYPRESS from your lower level routine, you consider a key press has been terminated.
    Otherwise, if you receive KEY_PRESSED three times, you consider that to be a valid 3-press instance.
