Hi! I am not too familiar with circuits, in fact this would be my second mini project, but I am out of ideas.
[Sorry for the topic name, it is not high voltage, that was a mistake. Moderators could you please remove that misleading word?]
I have a device that measures if 12 VCC is present on a circuit. However this device sometimes also connects its own 12 VCC on the very same circuit.
What circuit do I need to 'filter this out', so I detect only 'foreign signals'?
Eg. the measured circuit has a lamp as a load. The device will check whether it is switched on or not. However, at the same time, the device regularly lits that lamp, but the device should not detect this, only when it is done by something else. So clearly I cannot just connect it parallel like this, because that would make the device also detect itself. I though about relays, but they may not be fast enough to detach the detection line before the device detects itself.
Any ideas are welcome
