Desperate help needed with circuit diagram
Discussion in 'The Projects Forum' started by Manghameister, Jan 9, 2009.
  1. Manghameister
    Jan 9, 2009
    I am a complete electronics amateur, literally, i can barely even rewire a plug, but I desperately need help with this circuit. Its a counter circuit that simply adds one on with every pulse from a clock, however when i added in an SPST switch all of the counters and decoders blew up saying that the voltage had gone 6V over the limit. Any ideas would be very welcome.
  2. mik3
    Feb 4, 2008
    4,846
    63
    If I am right 74HCXXX logic family needs 5V for the supply voltage. Thus you can't apply more than 5V at their inputs.
  3. Alberto
    Nov 7, 2008
    169
    36
    Mik3 is right, you should use 5 volts not 6Volts! Use a 7805 and a 9 volts battery.
    Then you must add a 10K resistor and 100 nF capacitor from the common of every switches to ground, to avoid to mess up every thing when you use the switches.
    Have you grounded all the unused inputs of 74hc00 ? (From your schematic there must be two unused)
    pin 5 of 74hc4511 must be connected to ground
    Pin 5 of 74hc190 must be pulled up with a 10k resistor
    Never leave TTL inputs floating!
    Alberto
  4. mik3
    Feb 4, 2008
    4,846
    63
    Was the circuit working before adding the switch?
    Which switch is it?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Actually, it's never leave CMOS inputs open.
    Tie unused inputs to either +V or GND.
  6. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    The 74HC family may work from 2 to 6 Volts.
    The quote comes from this page :
    http://www.kpsec.freeuk.com/components/74series.htm
    Greetings,
    Bertus
  7. Manghameister
    Jan 9, 2009
    @mik3
    The problem occurs when I place an SPST switch in the left hand corner next to the power supply. I've attached a zip file that has a JPEG picture of the circuit that has slightly changed and the original file. Unfortunately it's in the format of a crocodile technology file so apologies in advance.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I've extracted the schematic and attached it.
    If you can, please use .PNG format files, as .JPG is a "lossy" format while .PNG is not. .PNG images are much easier to view as a result.
    I don't know what that item is to the left of IC6b (NAND gate, upper left).
    It looks like it's shorting out the battery the way it's placed.
    Also, in logic circuits, it's more typical to have a power switch in the + supply rail rather than the ground rail.
    You still have a lot of inputs that are not connected to anything. Connect them to ground or +V.
  9. mik3
    Feb 4, 2008
    4,846
    63
    I can say the same Sgt. The battery will blow when you close the switch. What is the problem Manghameister?
