desoldering through hole pads to ground, PLCC sockets, fine pitch
Externet
Joined Nov 29, 2005
2,220
Cutters clip the bottom out easily. Use any flux for leaded, 60/40 plain solder. Clean up by brushing residues with alcohol when done and absorb with paper tissue.
Does not matter if solder bridges short the pins. Briefly apply fine desoldering braid and they become neat instantly.
Practice finally makes it :)
Miguel
relicmarks
Joined Oct 13, 2006
355
Oh so you don't put the bottom plate back in after soldering?
Thanks for the advice i was confussed about this PLCC socket thanks
I used a Dremel tool with a hair thin drilling bit to drill out the solder in a through hole , it works really good
Thanks for the advice on that too
And the solder sucket notch tip was a good idea too , i did that
