Desoldering Station
Discussion in 'General Electronics Chat' started by roadey_carl, Jan 3, 2011.
  1. roadey_carl
    Thread Starter Active Member
    Jun 5, 2009
    116
    5
  2. debe
    Sep 21, 2010
    955
    185
    Looks good to me compared to what ive been using for the last 15Yrs.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I've used professional desoldering tools. I don't think you're going to like that unit for SMT parts. SMT, especially chips, generally use variations of hot nitrogen to heat up the board and part, and you use tweezers to pluck it off when the solder is melted. Of course, you have to be careful or the PCB is destroyed.
  4. roadey_carl
    Jun 5, 2009
    116
    5
    Thats pretty good it lasted 15 years, I've tryed one but It didn't last 3 months so it put me off!
  5. roadey_carl
    Jun 5, 2009
    116
    5
    Sounds expencive bill!
    I've only had to solder a few smd transistor and I managed to do that with a small soldering tip,steady hands and some flux! I've seen some people use heat guns before? I guess it easy to burn the chip and pcb with that though?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep. The unit you showed was for through hole parts. I've been using solder wick for most of my career to soak up the solder. It isn't the best, but it works.
