Hi there,
I am currently working on a PCB and am in the midst of soldering some of my components onto the board. However I have already made a mistake. I was soldering on some SIP sockets however I failed to inspect my positioning of the sockets. They now soldered in with slight angle, enough such that the component can not fit into the socket properly. I have tried desoldering with a pump and I got most of the solder off, however there is still enough solder that the component is connected. There is not much solder but it is too far in for the desoldering pump to completely remove it.
I was looking for some advice as to how I could try and fix my mistake.
