Designing T Flip Flop using JK
Discussion in 'Homework Help' started by Extreme112, Apr 16, 2015.
  1. Extreme112
    Apr 16, 2015
    I just want to double check my answer. I remember doing this same question a few months but I remember taking more time than I did in this 2nd attempt. So I probably something wrong in the work below. scratch-page-001.jpg
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    If Q is LO, then you are making J and K both LO. What is the next value of Q in that case?
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Also, your T FF has a control signal T, right? Where is T in your circuit drawing?
  4. Extreme112
    Apr 16, 2015
    So I did this again and I ended up with:
    J = T and K = (T)'. Is this correct? I think I ended up using the excitation table incorrectly.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    So...
    if T=0, then you will have J=0 and K=1. Will that give you what you want?
    if T=1, then you will have J=1 and K=0. Will that give you what you want?
    Always ask if your answer makes sense.
