designing synchronous counter
Discussion in 'Homework Help' started by keung, Dec 2, 2006.
Thread Status:
Not open for further replies.
  1. keung
    Dec 2, 2006
    I am designing a synchronous counter , but a problem occur in the karnaugh map, What should I do if the karnaugh map doesn't have any 1, just the 0 and don't care.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think it is likely you've made a mistake. Karnaugh maps are no substitute for correct logic design. They are tools to help recognize optimal implementation strategies once the boolean equations have been written in sum of products form. It is not necessarily the best or only minimization technique that you can use.
    Can you elaborate on the situation that you describe?
  3. Xolisa.X
    Apr 14, 2008
    9
    its easy when you build it,you just connect it to ground
  4. sndpgr
    Member
    Jun 22, 2006
    23
    No ones ! the output never is high! If you elaborate maybe we'll try and help!
  5. veritas
    Feb 7, 2008
    167
    This thread is like 2 years old
    - it should be locked
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Good suggestion.
Thread Status:
