Designing of 3 phase rectifier
sudharshan.panduranga
Joined Apr 10, 2008
65
Hi...
Can any one help me for the designing of 3 phase rectifier using Yie-Delta transformer and rectifier diode to drive 5watt load by applying 17vDC constant voltage to the load.
Transformer has the current transformation ratio of 5A/0.75A.
Joined Apr 10, 2008
65
Bill, your link didn't imbed properly.
Here's the link:
http://www.allaboutcircuits.com/vol_3/chpt_3/4.html
In AAC am not getting sufficient information about CT primary to secondary transformation calculation when connected in STAR-DELTA form.
The CT has
Primary=10A
Secondary=1.5A
Whwn 3 phase input current is applied to the CT primary, what current and voltages are developed in the secondary of the CT?
Pls give hints.
