Designing home made game wheel FF
Discussion in 'The Projects Forum' started by rcarabaj, Aug 26, 2009.
  1. rcarabaj
    Apr 10, 2005
    7
    Hello :)
    I would appreciate any information about projects to built a force feedback driving wheel, capable to be used with modern simulators. I tried to find inventors or experimenters they have attempted it, but it seems to be a difficult matter.:eek:
    Thanks for your attention. My best regards.;)
    Roberto
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Here is a link to an explanation of how the technology works - http://electronics.howstuffworks.com/joystick8.htm
    The motion commands seem to come over a USB cable. A dedicated driver seems necessary to transmit from the PC. If you can get information as to the codes/data sent out and program a microprocessor to translate them to the correct motions, then all you need is the interface to the motors that will make the wheel kick.
  3. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Its easy to build electronic devices for computer, but the hard part is to find the right device drivers for windows. If it isn't a certified one, windows wont even show it on the games hardwares. And then games wont initialize it if windows doesnt take it. So be picky. It needs microcontrollers if they need to be able to be played with new games.
    Another easier option if its just a wheel with force feedback is all you need would be to modify a cheap USB joystick with dual shock and analog and remap the analog controls to the wheel.
  4. Steve C
    Nov 29, 2008
    86
    I've also noticed that force feedback tends to come with big bass. explosions, impacts, that sort of thing. You can easily install a speaker without na enclosure to whatever you'd like the feedback for (like a chair, for instance), hook it up to the sound card with a big amplifier. Without an enclosure it will produce little sound if any and provide a tactile sensation.
    Assuming feedback is linked to low frequency program material in your game.
