Designing first order Butterworth low pass filter
Discussion in 'Homework Help' started by naspek, Feb 17, 2010.
  1. naspek
    Feb 17, 2010
    45
    Hey there.. This is my homework..
    i really need someone who can check whether i'm doing
    it right or not.. =)
    Question:
    Design a first order Butterworth low pass filter with cut-off frequency fo = 20 kHz and the gain K = 1
    fo = 20kHz
    K = 1
    When K = 1, we can ignore R1 and Rf
    formula :
    ωo = 1/RC
    2∏fo = 1/RC
    Set R = 1kΩ
    2∏fo = 1 / (1000) C
    C = 1 /
    (1000)(2∏fo)
    C = 7.96nF
    Answer: R = 1k
    Ω ; C = 7.96nF
    My answer is correct? :)
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Your answer is correct.
    naspek likes this.
  3. naspek
    Feb 17, 2010
    45
    ok! done with the first part..
    now is the complete question..
    Design a first order Butterworth low pass filter with cut-off frequency fo = 20 kHz and the gain K = 1. You will need to simulate the circuit using Multisim and shows that the circuit meet the required specification.
    i)Show all calculations steps and assumption made in your circuit design.
    (DONE!)
    ii)Show the circuit schematic with all the resistor and capacitor values labelled.(attachment)
    iii)Perform frequency response analysis on the circuit and obtain the bode diagram. The bode diagram should show the voltage gain (Vout / Vin) in dB vs the signal frequency (0 to 100 MHz). Does the -3dB cut-off frequency match the desired cut-off frequency fo = 20 kHz ? Explain. From the graph, estimate the roll-off rate. (attachment)
    I inserted my schematics and graph.. am i right?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The opamp has nothing to do with the simple RC filter.
    naspek likes this.
  5. naspek
    Feb 17, 2010
    45
    what do u mean? :confused:
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The simple first-order lowpass filter is just the resistor and capacitor. It must have a fairly high resistance load. An opamp has a very high input resistance and can be used as an output buffer if needed to drive a fairly low resistance.
    A second-order Butterworth filter must have an active amplifier like a transistor or opamp.
    naspek likes this.
  7. naspek
    Feb 17, 2010
    45
    ok... should i add RL in my circuit?
    other than this problem, my circuit is correct?
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    The Rl in your circuit is whatever the opamp is driving. The load of your RC lowpass filter is the extremely high input resistance of the opamp.
    Your circuit is correct. It is an RC lowpass filter with an opamp buffering its output.
    naspek likes this.
  9. naspek
    Feb 17, 2010
    45
    ok.. so.. the value for RL , can i choose it randomly
    or, there is formula to get the perfect value for RL?
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    The value of Rl in your circuit has nothing to do with the simple RC lowpass filter. It is the value of the resistance that the opamp is able to drive.
    There is no perfect value for Rl of an opamp. It is 2k ohms or more for ordinary opamps.
  11. naspek
    Feb 17, 2010
    45
    is my answer is wrong, if i didn't include the load resistor?
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    It is phoney baloney school work, not a real circuit.
    Nobody knows what is the value of the load. It could be anything.
    The quiz should have listed the load resistance if it is important to the calculations of whether the circuit will work or not.
    naspek likes this.
  13. naspek
    Feb 17, 2010
    45
    so.. i can ignore the RL right?
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    Your schematic does not have an RL so it doesn't matter. The opamp is not needed.
  15. naspek
    Feb 17, 2010
    45
    so my schematics is correct?
    what about my graph? i use AC Analysis to plot my graph..
  16. Audioguru
    Dec 20, 2007
    9,411
    896
    You zipped the file instead of posting the schematic and graphs. I don't want to unzip it again so I don't know if your schematic is correct.
  17. naspek
    Feb 17, 2010
    45
  18. naspek
    Feb 17, 2010
    45
    the above, is my schematic and graphs.. =)
    really hope you can guide me solving my problem.. =)
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    Your schematic shows an opamp without a power supply so it won't work.
    I don't know what you are asking about it because it is extremely simple.
  20. naspek
    Feb 17, 2010
    45
    where should i placed the power supply?
    i thought V1 is my power supply..
