Designing DC Bias Circuit
Discussion in 'Homework Help' started by sparkey2000, Aug 12, 2008.
  1. sparkey2000
    Mar 9, 2008
    8
    Please can someone help me answer the attached question; I can work through examples and calculate IC, IE, VCE, IB and VBE etc.
    However I'm stuck with the following question and I will need to do this for an exam this week; and help will be much appreciated.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What results have you got for the problem?
  3. yubyub
    Member
    Aug 13, 2008
    19
    6
    Rc + Re ~= 16k, since Vcq = Vcc/2, Rc ~= Re = 8k
    Ib ~= 6.67µA R1 ~= 2.4M (i think?) R2 = R1?
    Those are approximations, and i'm not sure about R1, R2. The lack of working would cause you to get no marks though.
    Assuming you have a textbook with BJT's, you should have no problem doing the working out properly.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Vcq equals 8 volts because it is half the Vcc, thus Rc=(Vcc-Vcq)/Ic
    Rc=8V/1mA=8K
    then we assume that Ie equals Ic and that Ve equals Vcc/10
    thus Re=Ve/Ie=1.6V/1mA=1.6K
    then we assume that R2 equals 0.1*150*Re
    thus R2=24K
    then Vb equals Ve+0.7=2.1V
    then make the voltage divider equation to find R1
