Designing bandpass filters for harmonics Project
Discussion in 'The Projects Forum' started by PMB917, Mar 7, 2006.
  1. PMB917
    Mar 7, 2006
    5
    I'm putting together a project for school (ITT Tech Woburn MA) that deals with harmonics of certin tyes of waves. (square, triangle,sawtooth ect.) I need to design variable gain bandpass filters for 2kHz, 4kHz, 6kHz, 8kHz and 10kHz.
    There are a few ways to do this, and I've found one way to do this with only one op amp.
    http://www.elecdesign.com/Files/29/4481/Figure_01.gif
    The only problem here is that they dont give any formulas for setting the center frequency or Q.
    Anyone farmilure with this design?
    I also had another thought to use a multiple feedback bandpass filter design.
    http://www.captain.at/electronics/active-filter/
    But that would mean I'd need twice the number of op amps to be able to vary the gain.
    I could go sallen key but then I'd be upto 3 op amps per harmonic totaling 14 and theres only so much room on a breadboard.
    anyone got suggestions?
  2. CoulombMagician
    Jan 10, 2006
    37
    Try a switched cap filter( see linear tech website for ICs). The center frequency is proportional to the clock frequency which can be varied easily. You need a filter circuit with a fixed bandwidth that is independent of the cneter frequency however.
