Designing an Solid State Relay
Discussion in 'Homework Help' started by shosh, Nov 14, 2011.
  1. shosh
    Nov 14, 2011
    5
    Hi, im new to this forum
    The reason I joined is because i need to design a solid state relay. Problem is, I'm not sure what it even is. During the semester, we touched on circuit analysis, mainly just RC circuits and really nothing beyond that. The course is kinda all over the place, touching on phase shifts and the like. seems like im unprepared to do this sort of thing. Can anyone be of assistance? any help would be greatly appreciated.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    In principle the SSR is an optically coupled / controlled isolated bi-lateral switch. So in creating a design you must incorporate those two ideas. An opto-coupler device would be probably be part of the design.
    A triac can notionally conduct both ways so that might be an idea for the switching part.
    Have you Googled SSR's?
    Hope you like the forum.
    shosh likes this.
  3. shosh
    Nov 14, 2011
    5
    at the risk of sounding like a complete idiot, i'd have to ask what is the purpose of a relay? im only in my second year and this is the first real engineering course im taking.
    the circuit actually seems simple enough, but my working experience are with ic chips and simple logic design so far with batteries as a power source.
    http://idobartana.com/hakb/SSR/circuit.html
    im guessing this is the circuit i need to build.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    optically coupled TRIAC
    shosh likes this.
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    1) low power circuit can switch high power AC load
    2) control side is isolated from the AC
    shosh likes this.
  6. shosh
    Nov 14, 2011
    5
    Ok, so looking back, I have worked with a relay,a solenoid. Iirc,it was a device I can electronically control to open and close a switch. Naming states as NO,NC. So looking at that link I have, how would I drive a light bulb with that schematic?
    Thx for yourhelp so far.
  7. shosh
    Nov 14, 2011
    5
    any help? sorry for the impatience, but i need to accumulate parts this weekend.
    So my main problem is hooking the SSR to a incandescent light bulb, or some sort of motor. I'd have to hook this up to an AC power source and i have never worked with AC power really, especially right out of a wall socket. Anyone guide me to a way to hook this up to a light bulb? specifically parts and materials i need. Also precautions, especially precautions.
  8. praondevou
    Jul 9, 2011
    2,936
    489
    Since you actually want to BUILD the circuit I don't think you will be able to get help here. Your circuit will not be isolated from mains which is a subject that's not allowed to be discussed on AAC, according to the ToS.
    What you want to achieve is very easy, but without the necessary experience it's also dangerous. I really don't know why they would ask you to do this without even knowing the necessary components.
    shosh likes this.
  9. shosh
    Nov 14, 2011
    5
    oh, i didn't realize that you couldn't talk about using main line power. Well is there another way to drive a bulb without using mains? The conditions of the project is to use about 5-30 VDC to drive a 50-120VAC load.
