My task is to design an amplifier with the following specifications.
-Open circuit voltage gain of 100 (+-)10%
-Input resistance greater than 1k ohm
-Operate on 12v supply
-Voltage swing of (+-)2.5 volts around q-point
The design must only use capacitors, resistors, and 2N4401 transistors
I really have no idea of where to start, and what to do. I have a basic knowledge of circuits and transistors, so if I could get started in the right direction I might be able to design it.
Thanks in advance
Thanks in advance
