Nope, R2 and R3 are the current setting resistors.
Not sure what you mean by that, could you clarify?Is there any suggestion to this circuitry and the key thing which i found out is the impedance of the op-amp with R6 has to be extremely huge which is unbelievable.
I have tried using a 100KΩ for R6 at first which i got a 70mA output reading, this is due to a voltage drop which is huge across the resistor which is unwanted.Not sure what you mean by that, could you clarify?
i believe i know what you mean. I am having this adjustment at the moment which allows me to only adjust both my current and voltage values at the same time with only 1 potentiometer which is R5.I suspect some of your values aren't what was originally defined. Within limits much of this circuitry is extremely predictable. Remember, the current control takes precidence over voltage, if you try to draw too much current it goes into constant current mode, and will regulate to whatever the current control is set for.
Without setting the potentiometer of R3 to either it 11V or 14V.The output voltage produced with the current as well can only be adjusted with R5. I tried using a current meter and a voltmeter, it perform exactly the way i mention.To actually adjust current try connecting a current meter DVM to the output and adjust it. Current only adjusts if it is current limiting mode.
Well an ammeter and i am well aware that it has to be connected in series in order to measure the current. But is there a way you can suggest me to measure the current.What are you using to measure the current?
You can't have 19mA into the emitter, that same 19mA flowing out of the base, and still get 0.98mA out of the collector. Transistors don't generate current.
by Don Wilcher
by Aaron Carman
by Aaron Carman
by Jake Hertz
