I have been doing some measurement and calculation on my board which i found out alot of values are not ideal. I understand that no circuit is able to get an ideal reading, however is there any component maybe like a capacitor that can be added for more ideal readings?When you asked for 10KΩ pots that set one of the parameters. The required voltages to the various parts set the other, from there it was a simple matter of dropping the values and watching what dropped out.
Hi ok thanks for that info. Can i also ask for more information on the power supply course which u were talking about previously.. Power supply course 102 if i remembered.You aren't going to get exact values most likely. You can tweak values with test select resistors, if it is important to you. Most times in electronics we judge what we will consider acceptable as far as offsets or tolerances. If you want exact values you can use on board pots to tweak some of the other components.
You could add pots for R4 and R3 to tweak the values to exactly what you want. Personally I don't think it is worth the bother. A smaller value for R3 and R4 would increase the ranges, and visa versa.
Well i am able to calculate them and on how they are supplying the voltages to the respective circuitry. To my understanding, R2 and R3 plays an important role for the current limiter which CR1 plays an important role which separates the voltage between R4 and R5 resistors which holds the voltage to the voltage regulator.R2 and R3, and R4 and R5 are both voltage dividers that control the setting. Have you worked on figuring out voltage dividers?
You can increase the voltage output of a 78xx series regulator by adding resistance between it's ground pin and GND.
There is a nominal 5mA current flowing from the ground pin to GND, so for every 100 Ohms resistance you add between the ground terminal and GND, the output voltage will increase by 500mV.
E=IR, so since I=5mA and R=100, E=0.5V or 500mV.
Note that Vout cannot be greater than Vin-2.
by Duane Benson
by Duane Benson
by Aaron Carman
by Aaron Carman
