designing a pwm circuit
Discussion in 'The Projects Forum' started by larz, Nov 21, 2014.
  1. larz
    Nov 18, 2014
    Its a school project, i need to follow the flow chart given
    This is what i have so far
    Any tips, hints or obvious errors in the circuit??
  2. DickCappels
    Aug 21, 2008
    2,755
    665
    It looks like a well though-out design!
    The output transistors might get hot -maybe better to turn around so their emitters are connected to the supply rails which would allow them to be saturated they could saturate (as well as a Darling can saturate). That might require the use of a couple of transistors to drive them.
    Current limit such as in the circuit below would be a good idea.
    The LM411 is apparently up to the task as far as output current and speed are concerned but its an opamp so you might have to add a little bit of hysteresis to prevent oscillation when switching output polarity.
