I want to design a circuit that converts a negative to positive signal into a range suitable for a single supply ADC.
the input is coming from a 120VAC input fed to a step down 10:1 ratio transformer which will outputs 12VAC signal.
is there a circuit that would convert the ±12VAC signal into a 0 to 3.3VAC signal so that it can be sampled by an ADC on a 3.3V microprocessor?
thanks in advance
thanks in advance
