Designing a Kitchen Timer using IC's and logic gates .
Discussion in 'The Projects Forum' started by rellik650, Mar 30, 2016.
  1. rellik650
    Mar 29, 2016
    6
    Hello , I want to create a Kitchen Timer that has 3 input buttons : 'Start/Stop' , 'Set Minutes' , 'Set Seconds' .1)When you set minutes and seconds and press Start/Stop , the timer starts counting down until reach 00:00 on a BCD 7-segment Decoder ,activating an alarm(or just an simple led) .2)If the output is 00:00 and you press Start/Stop button it count up to 99:59 and then 00:00(and it stops).
    Do I need 2 sets(1 set = 4 counters , 2 for minutes , 2 for seconds) of counters to produce the both cases?How to design propely?
  2. rellik650
    Mar 29, 2016
    6
    Sorry for triple posting . Can admin delete 2 of them ?
  3. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Cheaper to buy one than build one.
    Are you building this to gain experience, or simply because you need a timer?
  4. rellik650
    Mar 29, 2016
    6
    Gain experience .
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    MOD NOTE: The other two threads (neither of which had any replies) have been deleted.
  6. rellik650
    Mar 29, 2016
    6
    anybody?
  7. Dodgydave
    Jun 22, 2012
    5,154
    772
    Get on ebay plenty of choice and cheaper than making one.
  8. dannyf
    Sep 13, 2015
    2,196
    417
    Most of them are done via specialty asic or mcu.
  9. tracecom
    Apr 16, 2010
    3,879
    1,396
    Here is a video that describes a countdown timer similar to what you are wanting. The project was designed by another member here and built by me; it does a little more than what you want, but not much. As you can see, the project is a bit complicated, but it may help you understand why some of the responses recommend buying rather than building.
    absf likes this.
  10. rellik650
    Mar 29, 2016
    6
    I know that the idea of buying is better than building . I want to implement it to a FPGA so I need a basic scheme to see the internal process .
  11. TheButtonThief
    Feb 26, 2011
    219
    38
    Is this a homework/coursework assignment? The criteria you gave us sounds very specific.
  12. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    In the FPGA library there should be a presettable decimal up/down counter with both carry and borrow signals, similar to a 74LS168. One set of four of these form the counting core of the circuit. Then add steering logic around them to handle the operational conditions.
    ak
    rellik650 likes this.
  13. rellik650
    Mar 29, 2016
    6
    Yes !
  14. ian field
    Oct 27, 2012
    4,447
    791
    Kitchen timers have always been a popular page filler in various electronics hobby magazines.
    There are probably PIC or AVR based variants in more recent issues.
    Probably a few projects floating about the web too.
