designing a 50khz transformer
Discussion in 'The Projects Forum' started by vikramb, Feb 21, 2008.
  1. vikramb
    Feb 13, 2008
    7
    can you plz
  2. scubasteve_911
    Dec 27, 2007
    1,202
    That's a serious undertaking, which is why I don't think people are responding right away.
    I would start here,
    http://www.mag-inc.com/selection_matrix.asp
    You're going to need a good sized e-core or toroid for 1KW. You must be extremely concerned about your magnet wire quality and insulation, otherwise your circuit will arc and fail prematurely. You should consider litz wire for lower copper losses.
    I would go to the library and take out a book on the subject, I have seen many in my university's library that detail construction of switching transformers. I cannot remember how to calculate the appropriate turns, but I know the information is readily available.
    Steve
  3. legac
    May 4, 2005
    54
    1Kw@50Khz transformer is not too big. You can compare that with a commercial PSU of the PC. Commercial PC/PSU can deliver 400watts with a 42x 35 mm ferrit EI core. It is about 1/6 turn per volt. How about the wave form? This would affect the computation.
  4. legac
    May 4, 2005
    54
    Double posting. Moderator may help me to delete this. Thanks
