design with an op amp
Discussion in 'Homework Help' started by Kin Moon Kong, Jun 21, 2015.
  1. Kin Moon Kong
    Jun 21, 2015
    5
    I had a school assignment to submit i understand the two rule of an ideal and practical use of op-am. The properties of non-inverting, inverting and summing amplifier. but i am struggling with my assignment, which require your help. I was given ten option to choose i pick option 6. the question is: Given that the pressure sensor produces an output voltage (Vs :sensor output voltage) according to the equation Vs = (Px0.131)+1.683. This equation can be expressed in terms of pressure (P) versus sensor voltage (vs)i.e P=(vs – 1.683)/0.131 You are to design the amplifier circuit for this sensor using any combination of inverting amplifier, non inverting amplifier, summing amplifier together with a 1V reference voltage source. The two input signals of this circuit are sensor voltage (Vs) and an 1V reference source (Vref) and the circuit should produce an output voltage (Vo) indicating the pressure (PSI) according to the equation Vo = P(PSI) i.e When P=0PSI, Vo=OV When P=10PSI, Vo=10V When P= -10PSI, Vo= -1OV
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    Okay. So what is your question?
    You say you picked option 6. Are we supposed to be mind readers and simply know what option 6 is?
    Here's a concept: YOU need to show YOUR best attempt to answer YOUR homework.
  3. Kin Moon Kong
    Jun 21, 2015
    5
    read carefully !
  4. ericgibbs
    Jan 29, 2010
    2,581
    389
    Do you mean you had to choose a question from a list of 10 questions and you chose question 6 from the list.?
    Can we see your attempt at the answer?
  5. Alec_t
    Sep 17, 2013
    5,961
    1,133
    Hint: there are two things you need your opamp(s) to do:
    1) scale a value,
    2) sum two values.
    Consider how you will configure the opamp(s) to achieve those functions.
  6. Kin Moon Kong
    Jun 21, 2015
    5
  7. Kin Moon Kong
    Jun 21, 2015
    5
    thanks Alec
  8. Kin Moon Kong
    Jun 21, 2015
    5
    but how do I find the RF and other resistor values?
  9. panic mode
    Oct 10, 2011
    1,328
    305
    you draw some circuits, write equations and solve them.
  10. atferrari
    Jan 6, 2004
    2,663
    783
    The thread's title is wrong. He is tasked to use an op amp (or many).
  11. atferrari
    Jan 6, 2004
    2,663
    783
    Block diagram maybe? That would help to get a schematic I think.
  12. panic mode
    Oct 10, 2011
    1,328
    305
    most basic opamp circuits are just inverting and non-inverting amplifier (the only simpler one is voltage follower).
    circuits are simple and once the gain is derived, it is easy to see which one is to be used.
  13. Ricky Sum
    May 6, 2016
    13
    Hi, do you have any reference for your this project.
  14. Alec_t
    Sep 17, 2013
    5,961
    1,133
    I doubt the OP has any interest in this now, Ricky. The thread is nearly a year old!
  15. Ricky Sum
    May 6, 2016
    13
    Because I same one assignment quick similar to this. So I need some reference.
  16. WBahn
    Mar 31, 2012
    18,079
    4,917
    What kind of reference are you looking for? A complete circuit that you can copy and turn in as your own?
    thumb2 likes this.
  17. Alec_t
    Sep 17, 2013
    5,961
    1,133
    See post #5. Where are your efforts so far?
  18. Bordodynov
    May 20, 2015
    670
    194
  19. dannyf
    Sep 13, 2015
    2,196
    417
    Just decompose your equation into templates for opamp modules.
    Here, it is
    Vout = k x (Vin - V0).
    So it is a non inverting amplifier for k > 1 (solutions exist if k is less than 1).
    You just need to rewrite it to match the templates.
