I want to design transformer to step down from 120 V @ 60 Hz on primary to 15 V and max 1 A of current on secondary . To make winding easy for me I am going with EI core.
I hope to utilize Kgfe (core geometrical constant) method how to determine core size but even if I had spent countless hours looking into datasheets of different manufacturers (I don't want to break any anti-advertisement rule here, but one of them is mentioned in linked pdf about Kgfe method in the beginning of example #1. ), I wasn't able to convert provided specs into Kfe (core loss coefficient) and Beta coefficient.
Given that core loss Pfe = Kfe*(dB^{Beta})*Ac*lm
Can you point me out as how to use this method with data which are actually available?
Thanks.
Thanks.
