Design small signal midband common emitter amplifier bjt transistor
Discussion in 'Homework Help' started by alyrajaie, Nov 22, 2015.
  1. alyrajaie
    Nov 22, 2015
    Hi all,
    Could u all please help me to design common emmitter amplifier ( voltage divider config for dc analysis) which re the requirement as per follow:
    1) beta = 160
    2) vbe = 0.7
    3) overall voltage gain (with load) =larger than 90
    4) ac output signal vs = 50mV
    5) source resistance Rs = 1K ohm
    6) load resistance Rl = 2K ohm
    7) -3db cut off freq
    8) voltage supply dc (+5v) and (-5v)
    I need to calculate all the resistors, capacitors, -3db cutt off freq, input resistance, output resistance, max voltage swing and the stage voltage gain...i also need to do the simulation to prove that calculated value..
    Thanks to your advised...and have a nixe day
  2. DickCappels
    Aug 21, 2008
    2,782
    675
    We won't do it for you but can offer advice. To get started, please show us what you have so far.
  3. alyrajaie
    Nov 22, 2015
    Tq sir..im appreciate this..Firstly....i have read some calculation to get the value of resistors and others..but i still confius how to het the value using data sheet....pls refer the attachments....tq so much....how to determine the min beta....ic...and so on using data sheet..
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    But they give you the beta value, β = hfe = 160 and Vbe = 0.7V so you can start your designing process.
  5. alyrajaie
    Nov 22, 2015
    Tq so much....erm...how about the value of ic ( current )..or ie...please give me an advice....tq
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    Choosing the Ic current it up to designer.
    But you can start with Ic = (50mV*90)/2kΩ = 2.25mA . And are you sure about your amp spec?
  7. alyrajaie
    Nov 22, 2015
    Thanks again sir....ill try do this..
