Design Project Help ! :)
Discussion in 'The Projects Forum' started by jjuurreell, Sep 13, 2012.
  1. jjuurreell
    Sep 9, 2012
    23
    what OS usually used in touchscreen building directory? and what is the CPU used in it? thx.
  2. wayneh
    Sep 9, 2010
    12,373
    3,225
    I don't know about "usually", but Mac OS is used in many kiosks and I suppose Windows must be as well. These are gross overkill but I don't think it has so much to do with the OS as with the capabilities of the person setting it up. You use what you're familiar with to get the job done ASAP.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Quite often the OS think the touch screen is a common mouse pointer. All the complex task is handled by a driver
    absf likes this.
  4. jjuurreell
    Sep 9, 2012
    23
    guys, what board is used in kiosk ? can we make our own board ?
  5. lawncegary
    Sep 27, 2012
    6
    These are gross overkill but I don't think it has so much to do with the OS as with the capabilities of the person setting it up[​IMG]
