SORRY, I mean to rectify, make good, reverse. I, as you may have guessed am not an electronics engineer, I came up with the idea for this switch and employed an engineer to design the circuit board, he also put together the first batches of assemblies which were ok, but when I tried the last couple ready for dispatch I found an earth/ground fault, and when trying to contact the engineer he was having a breakdown, so using the plans and parts list I put one together myself,( did I tell you I wasn't an electronics engineer? ) anyway it had the same fault orange LED on, I spent many days going over drawings,learning what the various components do & then testing each section of the circuit, when I put a live test on it the orange light wasn't on and the only difference was that it was sitting on top of my computer so I put it down to damp, but it is now showing a dim red LED and a bright green LED when the polarity is correct, if i reverse wire it then the red is bright & so is the green which is correct, my question is why the dim red,where is the backfeed coming from?
Ive got another thread called just a quickie, if you look on there I managed to upload some pictures of the PCB,parts list and assembled unit.
Bazzer.
Bazzer.
