I have idea about 555 ic based circuit. but if I use it i think I need 5V
also I need to know how to calculate the lifetime for a one battery of torch
I can do it by measuring power requirements
but I do not know battery details
What is the forward voltage drop of your LED?
Look at the battery makers data sheet to see what is the maximum current that the battery can deliver. (I dont think it is even close to 50mA).
The capacity of that battery is only 18mAh or ~25mAh (depending who's figures you believe). So even if it could give ~50mA a charge wouldn't last long.
yes. also that is use push button which can't keep turn on without force.
is there any mechanical type push button once pressed turn on next press turn off.
I know they are available but I need one that height is less than 3mm
