Design of Switched Mode Power Supply(SMPS)
Discussion in 'The Projects Forum' started by rajesh.mahapatra, Jun 3, 2008.
  1. rajesh.mahapatra
    Jun 3, 2008
    Hello Forum,
    I have to design a SMPS having different voltage supplies.The specifications are hereunder:
    1) +24 V, 2 A
    2)-5V,+5V,-12V,+12V,1A
    3)+8V,+5V,+12V,1A
    Kindly provide me the design ideas and documents/links/pdf if any so that I can come out with the desired specification SMPS.Thanks in Advance..........
    Rajesh Mahapatra
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You've listed some combinations twice. Are they needed twice, or is this a typo?
  3. rajesh.mahapatra
    Jun 3, 2008
    No, the combination is not required twice. By mistake I wrote it....
  4. mik3
    Feb 4, 2008
    4,846
    63
    Search for boost dc-dc converters, buck dc-dc converters, inverting boost dc-dc converters and inverting buck dc-dc converters to see how they work and then combine them together to obtain your desired result.
    You can use a microcontroller to control them all.
    If you dont need these voltages the same time, why dont you build a variable voltage SMPS ?
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
