Design of an Op-Amp Circuit
Status
Not open for further replies.
Ricky Sum
Joined May 6, 2016
13
I HAVE A PROJECT BUT NO IDEAS START FROM WHERE, BELOW IS THE QUESTION
Given that the pressure sensor produces an output voltage (Vs : sensor output voltage) according to the equation Vs = (P x 0.131 )+ 1.683. This equation can be expressed in terms of pressure (P) versus sensor voltage (Vs). ie.
P = (Vs - 1.683)/0.131
You are to design the amplifier circuit for this sensor using any combination of inverting amplifiers, non-inverting amplifiers, summing amplifiers together with a 1V reference voltage source. The two input signals of this circuit are sensor voltage (Vs ) and an 1V reference source (Vref ) and the circuit should produce an output voltage (Vo) indicating the pressure (psi) according to the equation Vo = P (psi)
i.e When P = 0 psi , Vo = 0V and
P = 10 psi, Vo = 10V.
P = -10 psi, Vo = -10V.
STANDARD VALUES FOR RESISTORS AND CAPACITORS
(a) The standard E-12 values for fixed resistors are in the following ratios: 1 : 1.2 : 1.5 : 1.8 : 2.0 : 2.2 : 2.7 : 3.3 : 3.9 : 4.7 : 5.6 : 6.8 : 8.2.
Examples: 100, 120, 150, 180, 220, 270, 330, 390, 470, 560, 680, 820Ω OR 1k, 1.2k, 1.5k, 1.8k, 2k, 2.2k, 2.7k, 3.3k, 3.9k, 4.7k, 5.6k, 6.8k, 8.2kΩ OR 10k, 12k, 15k, 18k, 22k, 27k, 33k, 39k, 47k, 56k, 68k, 82kΩ OR 100k, 120k, 150k, 180k, 220k, 270k, 330k, 390k, 470k, 560k, 680k, 820kΩ OR 1M, 1.2M, 1.5M, 1.8MΩ, etc.
(b) The ratios for the standard values of the various types of capacitors are as follows:
(i) pF range – 1: 1.2 : 1.5 : 1.8 : 2.2 : 2.7 : 3.3 : 3.9 : 4.7 : 5.6 : 6.8 : 8.2 Examples: 100pF, 120pF, 150pF, 180pF, 220pF, 270pF, 330pF, 390pF, 470pF, 560pF, 680pF, 820pF, etc. (
ii) nF range – 1: 1.2 : 1.5 : 1.8 : 2.2 : 2.7 : 3.3 : 3.9 : 4.7 : 5.6 : 6.8 : 8.2 Examples: 10nF, 15nF, 33nF, 47nF, 68nF, 82nF, 100nF, 150nF, 220nF, 330nF, 470nF, 680nF, etc.
(iii)µF range – 1: 1.2 : 1.5 : 1.8 : 2.2 : 2.7 : 3.3 : 3.9 : 4.7 : 5.6 : 6.8 : 8.2 Examples: 1µ, 2.2µ, 3.3µ, 4.7µ etc..
1. REWRITE THE EQUATION WITHE INPUT ON ONE SIDE AND OUTPUT ON OTHER SIDE
2. CHOSE THE AMPLIFIERS AND DESIGN
3. SCHEMATIC OR CIRCUIT DIAGRAMS
4. ERROR CALCULATION OF THE COMPONENT (MUST BE LESS THAN 5%)
5. COMPONENT LIST
ErnieM
Joined Apr 24, 2011
8,377
You begin by finding the equation that when given the stated inputs from the sensor you get the required outputs. This is simple algebra. Two points make a straight line, you were given three which means you can self check your result.
Solving for Vs in terms of P will show you something importaint.
RBR1317
Joined Nov 13, 2010
713
That relation is important, but it is also a given. What is essential is to solve for Vout in terms of Vsensor because Vo/Vs is the transfer function that must be designed into the circuit.
Status
