Design lift control logic unit
Discussion in 'Homework Help' started by alwqas, May 7, 2012.
  1. alwqas
    May 7, 2012
    This question came as a project in digital logic design and i need some help
    Project Description
    In this project, you will design and implement a lift cotrol logic unit to serve a building containing eight floors. The design has also one more constraint that of being serving only two persons.
    1)
    Design a well suited lift cotrol logic unit keeping in view the contraints like safety, cost, power consumption, chip area, and speed.
    2)
    You have to simulate and test your design using LogicWorks or Logisim with clear mentions of the data sheets of each used ICs.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    So.... what's your question?
  3. n1ist
    Mar 8, 2009
    171
    16
    This project comes up at yearly. A search (you may also want to search for "elevator" or "dumb waiter") should give many hits.
    /mike
