design help
Discussion in 'The Projects Forum' started by bomrat, Sep 8, 2010.
  1. bomrat
    Dec 13, 2009
    25
    hi i have a sensor that outputs 1-6vdc and i need to design a circuit that will output 1-5vdc.
    thanks
  2. windoze killa
    Feb 23, 2006
    605
    24
    Voltage divider.
    Hint!!!!!!!
    More info in the question = more info in the answer.
    What is the circuit? What are you trying to drive?
  3. Kermit2
    Feb 5, 2010
    3,847
    963
    clamp the output at 5VDC with a zener?
  4. windoze killa
    Feb 23, 2006
    605
    24
    That won't give him the full range of voltage variation.
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    Amplifier with a gain of 0.83333
    Alternately, just use ohms law and set up a resistor divider.
