design for testability
Discussion in 'General Electronics Chat' started by vead, Jul 5, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    design for testability is process ensure that design has enough observability and controllability to provide for complete and efficient test
    test circuit is integrated to original circuit for purpose of testing
    Example - built in self test circuitry to original circuit
    - scan circuitry to original circuit
    built in self test - capability of circuit to test itself
    built in self test circuitry incorporated within chip for self testing
    test vector ---> original circuit & self test circuitry --> output response
    scan design - scan is technique used in design for testing
    test vector ---> original circuit & scan circuitry --> output response
    Q- how does test vector generate for built in self and scan design
    I think for scan we use ATPG to generate tset vector
    does we use ATPG for built in self test
    Q how does design make testable ?
    I think we add some flip flop and mux to make testable design
    Q can someone little bit how does circuit make controllable and observable
  2. ramancini8
    Member
    Jul 18, 2012
    447
    119
    The ultimate testable machine fits into either of two categories: first, there is a socket available that the test control cable plugs into (or an IC can be pulled to make a socket available), or second, the machine is so easy to disassemble that replacing parts is fast and simple.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Homework? :(
    vead likes this.
  4. MrCarlos
    Jan 2, 2010
    400
    134
  5. vead
    Nov 24, 2011
    621
    8
    yes I am studying about VLSI testing
    this post only I have asked about testable design how does vlsi circuit make testable
  6. vead
    Nov 24, 2011
    621
    8
    look at this post I asked question and given some option I don't want that someone explain in detail
  7. kubeek
    Sep 20, 2005
    4,691
    806
  8. Brownout
    Jan 10, 2012
    2,375
    998
    There are many many ways to generate test vectors, including Automatic Test Program Generation (ATPG)
    Scan cells, Boundary Scan cells and other special circuits or normal resources.
