design cycle counting
Discussion in 'Homework Help' started by morzer, Nov 14, 2014.
  1. morzer
    Nov 14, 2014
    design counter odd number and even number
    with cycle counting: 0-1-3-5-7-9-11-13-15-17-19-18-16-14-12-10-8-6-4-2-0
    use Flip flop (not use IC)
    help me
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What have you done to start the design process?
    Do you know how many flip-flops you're going to need?
    What are some of the special features of this sequence?
  3. morzer
    Nov 14, 2014
    This is my homework. I use 5 flip flop,
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Do you have a chart of the values for each flip-flop for each state? Can you show us the chart?
  5. morzer
    Nov 14, 2014
    True table, but I can't write logic functions. can you guide me?
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Rearrange the rows of the table so they are in the actual state sequence. Then look for patterns that you can use to your advantage.
  7. WBahn
    Mar 31, 2012
    18,093
    4,918
    What kind of flip flops are you using? DFF, JKFF, TFF?
  8. WBahn
    Mar 31, 2012
    18,093
    4,918
    I think the patterns are easier to see if the table is in the order of the states (as his table is) and not the sequence since the logic doesn't know or care about the prior or future members of the sequence.
    Notice that the first column is named in a misleading way. It should be called State and not Clk.
  9. morzer
    Nov 14, 2014
    DFF, or A kind of flip flop do not complex so use for my process
  10. WBahn
    Mar 31, 2012
    18,093
    4,918
    So, if you don't already know, spend some time getting comfortable with what a DFF is -- how it behaves and, specifically, how you can use logic to control what the next state of a given DFF will be.
