Design circuit that puts out 6v from 12v with no load
Discussion in 'Homework Help' started by yescircuits, Aug 29, 2015.
  1. yescircuits
    Aug 29, 2015
    20
    Question on homework is:
    Design and construct a circuit that puts out 6V (within 0.2V) from a 12-V power supply, with no load attached to the two output terminals. With a 500- ohm load attached, the output voltage drops to 3V (within 0.2V). Below is a diagram of a circuit that I built that should satisfy the first of this two part assignment but when I add a load of 500 ohms it does not drop to 3V. Any help would be greatly appreciated. 6V_12V_500ohm.jpg
  2. ericgibbs
    Jan 29, 2010
    2,602
    396
    hi y,
    Your circuit shows a 'link' across the 'load'.
    Where are you measuring the 'load' voltages on that circuit.?
    Hint: assume the battery negative is the 0V reference for the load.
    E
    yescircuits likes this.
  3. atferrari
    Jan 6, 2004
    2,672
    785
    Just in case, I built the same circuit in my bench and do not measure 6 V with my DMM connected as yours. Much less in fact.
  4. shteii01
    Feb 19, 2010
    3,516
    515
    Your volt meter is in the wrong place. The location where you have volt meter now, the volt meter should be showing 0 (zero) volts.
    Photoshop?
  5. yescircuits
    Aug 29, 2015
    20
    I will first try making the correct v reading. I will send a new schematic
  6. yescircuits
    Aug 29, 2015
    20
    Thanks will send new schematic soon
  7. yescircuits
    Aug 29, 2015
    20
    Image-1 (1).jpg Ok, it looks like I got Part A of the two part requirement for the lab assignment. Correct? I am sending the second part that I am now having trouble with
  8. yescircuits
    Aug 29, 2015
    20
    Image-1.jpg When I add 500Ω resistor I get 4.8V and not the required 3.0V? Can you please help?
  9. shteii01
    Feb 19, 2010
    3,516
    515
    1.
    Where is output voltage is taken?
    Across 1k resistor?
    Across 500 Ohm resistor?
    2.
    Do you know what Voltage Divider is?
    Do you know how to calculate values of resistors needed to build Voltage Divider?
  10. yescircuits
    Aug 29, 2015
    20
    In the above diagram the output voltage is taken across the 1kΩ resister. So part A of the assignment from 12V to 6V is correct? week1lab6.jpg Would the above be an acceptable design for part two of the lab assignment? Or am I not able to split the resistors and re-position them?
    I found my notes on voltage dividers...thanks for this help. Is there anything else that I need to know, for this assignment is due Monday night and I think I'm stressing over something simple.
  11. JoeJester
    Apr 26, 2005
    3,403
    1,227
    why not post a link to your assignment so everyone can see what you are suppose to do ....
    that way the assistance provided would be tailored to your needs.
  12. ericgibbs
    Jan 29, 2010
    2,602
    396
    hi yes,
    The question was, calculate the resistors to give 6V across the lower resistor, with No Load across the lower resistor.
    Then it says add a 500 ohm Load across the lower resistor, ie: in parallel
    What is the voltage now across the Load.? should be 3v.!!!
    OK.
    E
    EDIT:
    This is th question as I see it.
    Part A, looks easy, but
    Part B, with 500 ohm load will require some rethinking of Part A resistor values, in order to satisfy BOTH 6V and 3V , ie: without and with the 500 ohm Rload
  13. yescircuits
    Aug 29, 2015
    20
  14. yescircuits
    Aug 29, 2015
    20
    So it will take 5 resistors to solve, totaling 1.5k ohms? Thanks a lot for your help!
  15. jjw
    Member
    Dec 24, 2013
    174
    32
    No, it needs only 3 resistors.
    From part A you get the relation of R1/R2.
    In part B the load of 500 ohm is connected from the connection point of R1 and R2 to 0V ( parallel with R2 )
    The voltage over 500 ohm is 3V and from there R1 R2 can be calculated.
    ericgibbs likes this.
  16. yescircuits
    Aug 29, 2015
    20
    The below should wrap this assignment up. I am going to work on voltage dividers and this was a good jumpstart. Please let me know if the below two diagrams of the circuit fulfill the requirements, for I am going in to lab tonight at school to construct. Here is the assignment again:
    Design and construct a circuit that puts out 6V (within 0.2V) from a 12-V power supply, with no load attached to the two output terminals. With a 500- ohm load attached, the output voltage drops to 3V (within 0.2V). Below is a diagram of a circuit that I built that should satisfy the first of this two part assignment but when I add a load of 500 ohms it does not drop to 3V. Any help would be greatly appreciated. Image-1 (1).jpg Image-1.jpg
  17. jjw
    Member
    Dec 24, 2013
    174
    32
    Why you say that the voltage does not drop to 3V in the second diagram? It seems to be 3V.
    Is it enough that you have guessed the 1k resistor values or should you show how to calculate them?
  18. yescircuits
    Aug 29, 2015
    20
    My bad, that was a typo i ment to say it is 3v. Could you explain how you came up with the values please from the start. Thanks again!!!
  19. yescircuits
    Aug 29, 2015
    20
    just want to make sure that I'm going about this forum correctly...am I? kind of new at that stuff
  20. jjw
    Member
    Dec 24, 2013
    174
    32
    I can't do your homework,
    From part A you know that the resistors must have equal value, lets say R
    From B you know the voltages in the circuit. Try to solve the currents ( Kirchoffs law ) as a function of R and finally get the value of R.
    Alternatively make the voltage divider equation R series with R parallel with 500ohms, but it is more complicated to solve R from that.
